RCU Forums - View Single Post - World models P51 eletric conversion
Old 09-09-2005 | 08:20 PM
Cubano8
Default RE: World models P51 eletric conversion
ORIGINAL: Gaiotto
Thanks Cubano 8, great photos and beautiful airplane!
But, I don't undestand one think: If the WM Mustang has the same weight of your spitfire (at about 6.0 lbs), why I couldn't use the 2826/12 instead of 4120's? I don't want to use a expensive motor and for instance a 4S lypo. What do you think about that? I want a to use a lypo from quest, did I have to use a 4000mha or I could use a 2600mha?
Gaiotto
Sorry,forgot to answer your other questions.
Lets say your auw comes out to 6lbs. I like to 100watts per pound formula, so you will need 600watts. Please correct me if I'm wrong;
AXI 2826/12 max efficiency current is between 15 to 25amps, with a 40amp burst for 30sec.
so at 4s li-po which equals to 14.8volts x 25amps = 370watts
with the 30sec burst at 40amps your power is 14.8volts x 40 = 592watts
So you have a 30sec window of 592watts for take offs , full power bursts etc.
the rest of the flying should remain below the 25amp range.
Now, the time:
With a 4000mah battery:
4000mah x 60min = 240 divided by 25amps = to 9.6min of flight (at the 25amp range)
With a 2600ma battery:
2600mah x 60min = 156 divided by 25amps = 6.24 min of flight (at the 25amp range)
Now you are not going to be flying at 25amps all the time, but this is to give you an Idea of your flight times.
Another thing is you are not going to use the complete 4000mah or 2600mah, cause you Cutoff will kick in
So, I like the conservative route. Instead of 4000mah, I'll go with a 5000mah or a 6000mah, and be safe with a 10min flight, in which most of my flights are.
Question of Li-po and $$$$, Heres a link on some li-po that I'm considering, which are not bad fore the price.
[link=http://www.xushobby.com/servlet/Search?category=Li-poly+Battery]http://www.xushobby.com/servlet/Search?category=Li-poly+Battery[/link]
