RE: CH Ignition/minimum voltage?
Sounds like you may have a weak battery. The C&H ignition only uses about 200-400mah when running. You should be able to fly all day & more with a 1400mah. Not sure what voltage it will cut out at, but it will start "shooting ducks", when the battery gets low.
