RCU Forums - View Single Post - BREAKIN HELP
Thread: BREAKIN HELP
Old 09-10-2005 | 11:47 PM
Super_Dave's Avatar
Super_Dave
Default RE: BREAKIN HELP
Quick and high rpms means its running lean. If its while the throttle isn't open much especially at idle richen up the low speed needle. If its past 1/4 throttle richen up the high speed needle. You could also have an air leak. Check the seal around the fuel tank cap, loose carb or the main needle valve is loose where it screws into the carb, or a hole in your pressure line to the fuel tank.
