RCU Forums - View Single Post - Well i bought the Modeltech Mini Magic extra
Old 09-11-2005 | 12:28 AM
Dealspeed's Avatar
Dealspeed
My Feedback: (17)
Default Well i bought the Modeltech Mini Magic extra
Got a Bassicly brand new OS25FX sitting on the table, and a whole fleat of HS81's.
Plane looks pretty nice, was impressed with the qaulity as i have had bad experiences with global Aircraft, I will need to run some CA over all the stress points, as there is a lack of glue throughout the entire airframe so andybody else who may decide to buy this make sure you check all the stress points.
I havnt decided whether or not ill use the wire landing gear or change out to Light aluminum gear.
Accses to the landing gear plate is really good, wouldnt be hard at all to install some blind nuts for the solid gear.
Ill let you know how the build goes as i progress, should be a fast build as there isnt much assembly at all.
Heres the specs on the plane
Specifications:
Span: 35.5in. - 900mm
Area: 368sq.in. - 23.8sq.dm.
Length: 35.5in. - 900mm
Weight: 28 to 38 oz. – 800 to 1100g
Wing Loading: 11 to 15 oz/sq.ft. - 33 to 46 g/sq.dm.
Functions A/E/R/T
Servos: 5
Power: 20-30 Four Stroke, 15-20 Two Stroke, MPX480BL4T/G Brushless, 2-3 cell 2000 or greater liPo
