Replace servo with electronic on/off switch
unless those links said about this, try it..
i know you.. us car guys can kill a few servos, so you should have a few with stripped teeth.
take it apart, and if you can replace the pot with 2 2.5k resistors, use the centre wire as common, and the others to each end of a resistor.. now unsolder the motor and attach your electronics for 6V .5A switchable supply
