RCU Forums - View Single Post - Hanger 9 Edge 540 balance
Old 01-10-2002 | 02:33 AM
A10FLYR's Avatar
A10FLYR
Default Hanger 9 Edge 540 balance
Has any body assembled the Hanger 9 Edge 540? In typical Hanger 9 fashion it appears the Edge 540 will come out nose heavy if assembled according to the instructions. Has anyone put three servo's in the last tail section? That seems to be the only way to balance it with out a lot of lead. I was thinking of putting two elevator servo's, one on each side with short 4-40 rods and one in the bottom of the fuse with short cable to the rudder and tail wheel steering arm. (I'm not fond of using a tail wheel bracket that glue's to a split in the rudder post. I prefer to have a bolt on style under the fuse) I'm planning on using either a Super Tigre 3000 (1.8 CU.) or a Webra Bully, (2.1 CU. on alcohol), only 3 1/2-4 oz. difference in weight.
Also, it came with two wing spars, one attached to the wing package and one attached to the accessory package. Which one do I use?
