3250 idle problems
I Have an older 3250, by that I mean Italian made. It was broken in and then put away until I got it. It runs very weel turning a Zinger 18x10 at 7400 on powermaster 5%. However, after about 20-30 seconds at full open it wont come back to idle. It seems to hang around 3400 or so. My idle is about 23-2400 and it transitions really well. It sound like its going lean when I come back to idle. It takes between 15 and 30 seconds to come back to normal idle. I changed to the OS carb but it didnt changes at all. The only way I could make it work was to set the idle mix so rich it wont transition well. Anybody got an idea? Oh yeah I even changed to a cooler plug thinking it might be a heat issue after the higher rpm.
