RE: XXX-NT - Help required please!
Thanks for the replies.
Yep - I'm runing original brake bits and linkages.
It's almost as if the servo isn't going far enough around to pull the rod far enough. I've check the radio adjustments and have it the best I can.
How fast should these things stop, anyway....on a pin...or is there a few metres required to pull them up.
I've also checked the needles and gone from stock. When I put the engine in, I also cleaned and rebuilt the carby.
Thanks again,
Steve
