RCU Forums - View Single Post - Moki 1.80 with radial engine mount
Old 09-13-2005 | 10:20 AM
tonyc's Avatar
tonyc
Default RE: Moki 1.80 with radial engine mount
I like the radial mount. You can rotate this mount on the back of the engine so that the two holes are in any position. I have my Moki 180 set up so that the motor is at 90%, to the firewall, and the two holes are down at the bottom of the fire wall. The crank is right through the middle of the mount. You can see on this photo of my Ultimate the hole on the right hand side of the cowl for the glow ignighter.
Hope this all helps. By the way I use a Cline regulator and O% nitro.
tonyc
