Help with Modeltech 3-D Magic ARF
Hi Joe,
This plane is alot of fun.You should enjoy it.The CG is 4 1/8 inches back from leading edge.The throws are as follows.
Ailerons: low rate-1 inch each way high rate- 1 3/8 each way
Elevator: same as ailerons for low and high rates
Rudder: low rate-3 1/8 each way high rate-4 1/4 each way
Thats right from the manual.They also suggest -30% expo on low rates and -35% expo on high rates.If you have expo on your radio.
I have my ailerons and elevator setup with a little more throw than they suggest.1 1/2 on low and 2 on high.You might not need it,but it doesn't hurt to have it.I have a TT 46 pro on mine spinning an 11x4 prop.Good luck.
Hank
