RCU Forums - View Single Post - OFNA LX/MBX Comp Difference
Old 09-13-2005 | 01:01 PM
fishboy
Default RE: OFNA LX/MBX Comp Difference
Same car, except for the suspension, tires adn starter method.
LX- Kingpin suspension, 4 black tires, pull start
MBX - Ball Pivot suspension, six colored tires (4 blue, 2 yellow), electric start.
All of the other parts are identical. If you go witht he MBX be careful when starting it during break in. I'd loosen the glowplug a little when starting it the first 4 - 6 tanks as the pinch as the piston reaches TDC will put extra wear on the gears and motor int he starter.
