RCU Forums - View Single Post - Poulan 25 from FL trimmer
Old 09-13-2005 | 01:43 PM
  #127
diablo_r's Avatar
diablo_r
Default RE: Poulan 25 from FL trimmer
I tried glow very quickly, using an OS type F plug (the 4 stroke one) and 70% petrol, 5% oil, 3% nitro and 22% methanol with the glow powered all the time, it ran okay but I did not have enough time to set it up properly. I also know the fuel pressure is set too high on the carb but again time has stopped me playign with it. Its 25psi, it should be 15 and ideally 11. Bit of spring and needle arm fiddling required, that should improve the bottom end mixture too.
Cheers,
Rich
