RE: Fuji 50SB Surging at Midrange
You may have the high-speed or low-speed needles a bit lean. If richening one or the other, or both, doesn't cure the problem, you'll have to disassemble the carb and clean the screen. The screen is under the cover with the big screw in the middle.
