RE: Moki 1.80 with radial engine mount
jlchapman,
your mount is installed in the only position it that doesn't work. Remove the backplate screws and rotate the mount 180 degrees (or as suggested by tonyc ... put it where you want it) but don't put the single mounting hole behind the cylinder.
cheers'
RTD
