RE: homelite chainsaw
Carlos,
Mine had brass stepped washers between the roller bearings and the counter weights. I cut off the clutch shaft with a hack saw and dressed it with a file. It uses the HDA 60 so you must have the larger engine. The muffler is easy to modify.
Dave
