RCU Forums - View Single Post - GT 80 Question
Old 09-14-2005 | 09:36 AM
pe reivers
Default RE: GT 80 Question
The mist is caused by carb blow-back. This is caused by the inlet port closing too late, and mixture strength has nothing to do with it.
A carb stack increases air inertia, and thus may reduce the blowback problem, certainly when combined with higher rpm.
At higher rpm (smaller props) the engine will be more happy. You are now running it lower than the speed it was designed for.
