RCU Forums - View Single Post - Motor mounts
Thread: Motor mounts
Old 09-14-2005 | 09:45 AM
green-boat's Avatar
green-boat
Default RE: Motor mounts
I personally don't know where to get any that are ready made. I make mine out of aluminum angle and drill it out to fit the motor in question. The motor should have bolt holes in the front casing for mounting. If you feel adventrous enough you can cut out for the vent holes, I have yet to do this. I've never had a motor over heat as of yet, the aluminum does help remove some of the motors heat though.
