RE: which plane to get?
hi i wouldnt suggest any of those cubs are a handfull for a start !!if i were you id look at the gws e starter its a loveley plane and easy to fly it has aelerons so it does rolls too .its very stable at slow speeds and easy to repair if need be.the v tail style planes are easy to fly but theyre not a bit like a plane with rudder and aeleron controll.get the e starter its great even in a bit of wind!!.also the advantage of the gws birds is you can put all the electrics into a second plane even the motor too.take a look at theyre website and see they have loads of great planes!!!.i would say you could learn to fly yourself with this plane as long as you understand the basics !!
good luck
