RCU Forums - View Single Post - Sig Mayhem 3D ARF
Old 09-14-2005 | 01:56 PM
  #669
Big Barry's Avatar
Big Barry
Default RE: Sig Mayhem 3D ARF
Root
I try to put all of my fuel tanks on CG. I only use YS engines so it works for me. The tank in the picture was from a previouse plane, I hate to build tanks so I recycle. The packing tape was on the tank as part of the instalation in the previouse plane. The tank had a length of tape that stuck out into the fuse so that you could pull the tank out for mainainance. I was lazy and left it on. I have had one tank crack on the seam in the past, it was a hard plastic chinese cheap type, I probly shuld not have used it to begin with. All sulivan, Dubro and other stock tanks have all worked for me and the YS's. The packing tape cant hurt. The Battery is mounted next to the servo. I usally velcro strap my batt's so that I can move them around till I find my CG and then I Ziptie em in.
Good luck with the plane, its a keeper. You will eventually get another plane but you will always have fond memories of the Mayhem. I plan on always having one around, for me its like therapy only cheaper.
