RCU Forums - View Single Post - better way to screw on cowl!!!!!!
Old 09-14-2005 | 07:51 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: better way to screw on cowl!!!!!!
If you drill the hole slightly larger than the screw you attach it with, then put a piece of fuel tubing in the hole and then put your screw in. The fuel tubing will act as a "shock absorber" and isolate the cowl from the vibrations. A little bit of nyrod inserted in the wood also helps to keep the screw from vibrating back out. see attached diagram. I've done more cowls like this than I can count and it works every time.
Hope this helps
ken
