Rascal 40 Rolls
I have 18 flights on my Sig Rascal 40 now and am very pleased with it. As most here probably know, the Rascal is a high wing airplane, but has a semi symetrical wing and is supposed to be very agile as high wings are concerned. I'm just starting to get brave enough to do some aerobatics with it. I can knife edge with it somewhat, it has some coupling in it and needs up elevator to correct. I just about have this down.
None the less here's the question... When I roll this plane with Aileron only, I get a severe drop in elevation and a very gross looking roll at that! It's set up with the same throw in up and down on the ailerons and I'm wondering if changing the throw in the up direction will make these rolls any smoother. Are there any other suggestions?
Thanks for your help,
MPB
