RE: XXX-NT - Help required please!
Guys,
Thanks for the replies.
My fuel line is OK and I have no leaks or blockages. Carby was pulled down and rebuilt before I put the Epic in.
Brake disc, pads and linkages are all new.
The design of the pipe issue makes sense. I actually just popped on my stock Terra Crusher plastic pipe that used to run with the Epic. Primed quite easily and no spew of fuel during priming or stopping. Some one out here in Australia suggested that the Adam Drake pipe was only for .12 - .15 engines, so perhaps with the Epic, the pressure was all wrong.
I'll have a really good play with the radio adjustments next and see if I can get some better brakes.
How quick should the XXX-NT stop, anyway?
Thanks again for the suggestions.
Cheers,
Steve
