sky scooter question
have you got any fuel tubing? put some over the shaft just slighty more than the prop thickness, then put the prop on, and screw the nut down and the tubing will compress holding it firm... i guess... not seen the exact setup you have, but i guess it'll work.
i also didnt know they used slowfly props... i've only seen direct drive scooters with smaller higher pitch props .
