ORIGINAL: RCIGN1
G23 nope, G26, very close.Thge 26 was slightly stronger ..The 140 is physically smaller and fits in slimmer cowls because the rear carb setup...I replaced the carb mounting plate with a thicker one and put on a 3W spark plug cap, and made the pulse hole a little more direct...Nice little engine....[8D]
Do you use the built in Hall device? If so what is the pin - out? I would like to hook up a C&H unit to mine but they dont use standard colors on the wires. At least our standards they don't.
