RE: E-FLIGHT BLADE CP
Thank you DarkWombat
I will go through it and check everything again. The first thing I was going to do today was to get new batteries for the TX. They are down a little bit so I thought I would check and see if that does anything. I will check crystal connections and all that you suggested. I appreciate your explanation, knowledge and description of possible problems. I went to the LHS and was told to call Horizon cause they didn't know so I will do that also on monday.
Thank you again for taking the time to explain.
