RE: Reflection Servo Selection?
I used HS-55s all around. They work fine...plus that is what I had. You will need to enlarge each servo bay slightly on 2 sides to make them fit. It has been mentioned before, but make sure you get all those aileron linkages free. Even with a strong servo, there is enough flex in the plastic linkages and arms to prevent the ailerons from centering.
