RE: HB 25
[b]DSK:
See I missed part of your question. Radial mounting, directly to the firewall, would eliminate the weight of a separate mount. If you don't have to run your fuel lines through the center of the firewall, this mounting is practical.
A plastic composite mount does give some vibration isolation, but these little engines are smooth enough I don't think there would be any problem with the radial mount other than hose routing.
Just be sure to balance your props, and spinner if used.
Bill.
PS: Use a fuel with a castor/synthetic blend lube. They do not like all synthetic. wr.
