RCU Forums - View Single Post - Saito 82 and hovering problem
Old 09-19-2005 | 02:16 AM
homesickangel's Avatar
homesickangel
Default Saito 82 and hovering problem
My motor is starting to squeak intermitently and it sounds like the bearing on the props side which is the culprit. Can this bearing run dry and fail if you hover it ( the oil might not be getting to this bearing in a hover )? I am running a 14/6 apc prop.
