RCU Forums - View Single Post - walbro carb
Thread: walbro carb
Old 09-19-2005 | 10:17 AM
Prop Nut's Avatar
Prop Nut
Default RE: walbro carb
The low end adjustment is sealed using some type of glue, if you look into the end of the sliding barrel itself, you will se (deep down) a bit of redish glue, this is covering the slot for the low end needle. You can dig this out (I used a dental tool) and have the low end adjustment. Hope this helps. I have those carbs on my Four stroke gassers.
