RE: Skymaster Hawk Once Again (at least!)
Ali, I have checked the total length of the nose leg (about 200mm from mounting plate to ground)and it is right on the money and also it sits nicley on the ground just a little nose high. I also checked on what the ground attitude of the wing would be if I cut the steering shaft to allow the leg to contact the steering arm and it was going to be about -3 degrees so I have not cut it back.
I have been talking to Albert in Singapore and also Anton but I cannot get a reliable answer as to whether I received the correct nose leg or not.
Ron
