RCU Forums - View Single Post - ABC turns left.
Old 09-19-2005 | 10:23 PM
camlf
Default ABC turns left.
wing is ballanced. tail is repaired with cross dowel. boom is moded and tight. tail is squared and level. Boom may of been crooked comeing out of fuse. gave it a twist to its right and was flyable. But had to use full right trim. Got home and rechecked . Measure prop ends to wing. seems pretty stright. done the mod. Turns left hard at hand launch.
Checked servos. pointing at each other. Did correct methed of trimming with power on. Checked boom with stright edge. What am I missing.
Controll horns not damaged and same pull on both.
did get it to fly as I said after giving the boom at fuse a twist to the right and full right trim on the TX. As soon as I try to return the full right trim the plane goes left. humm... Thanx for your help.
