RE: Saito 82 and hovering problem
Gotta side with Bill and Hobbsy here. Some castor in the blend is your friend. Until you do get some castor in there, lube up the crankcase and cam box area real good with some air tool oil or Rislone engine treatment to help keep the rust away (might temporarly stop squeeling too). Being in South Africa, you may not have access to Rislone, so use any modern automobile engine oil instead.
