RE: One way front diff
They do help, but if you are a beginer you probably wouldnt even notce the difference and you would pobably do better without a One way.
A one way helps you get more speed in the corners, but it limits the amount of brake you can use. With front one-way you have to tune your brakes way way down, and you can only use the brake for a slip second, while your going perfectly straight, or else your car will spin out. Thats why drivers with a one way barely even use the brake during a whole race.
