Good Second Plane
I've seen too many hobbists just loose it when they start building and flying expensive jets and that they are not able to control with authority, this happens because they were not able to master the entire scope of flying, and their pockets were not as expandable as their egos. Most of the real flying will be learned on a tail dragger, things just happen differently then. There is a sequence to the art of flying model airplanes successfuly, and there are a lot of tricks that you must learn and master before tackling the powerful jets of today. You can still go from trainer to pattern style flying without much problem and then jump on to jets, if that is your wish. But following the learning curve will make you a better jock!
