RCU Forums - View Single Post - Genesis pinion gear mesh question
Old 09-21-2005 | 07:10 AM
topfuel
Default Genesis pinion gear mesh question
Has anyone tried setting the mesh on the pinion and spur gears as recommended be Jeremy from CEN in a previous thread. In it he states "be sure that the pinion gears are pressed tightly against the spur gears. They should not move freely." If you tried this what were your results? I tried it and I wore out the 1st gear pinion faster than usual. (Only 3 tanks of fuel ). Anyone else have better luck?
Also, what happened to CEN on this board. I haven't seen any activity from them in about a month? Just wondering.
TF
