RCU Forums - View Single Post - Indestructible Trainer
Old 09-21-2005 | 08:51 AM
  #35
Villa's Avatar
Villa
Default RE: Indestructible Trainer
Sorry for the repeat, but something fell off: dus10lee....Since you have not located gutter pipe for the fuselage, build a SPAD that uses 1/16 X 1 X 1 aluminum square tubing for the fuselage. Stores like Lowe's sell an 8 foot section for about $25.00. The trainer is VERY indestructible then. Make the wing like the SPAD DOMINATOR, using two spars. In between the two spars, at the middle, add a piece of aircraft plywood and a 1/4-20 NC blind nut. A steel bolt thru the aluminum tubing anchors the fuselage to the wing. A nylon bolt near the wing trailing edge anchors the wing to the fuselage. The engine attaches like on a SPAD3DT. Do a search under my, Villa, and you will find a Canard, two twin engine planes, and a flying lawn mower, all built as described above, and very indestructible.
