Ignition switching for RCIGN conversions
Hi
Should be getting my second Zenoah conversion back from RCIGN soon. I have not run the first yet.
My question is what kind of switches are you guys using for the ignition system. I am thinking about a servo-operated switch so I can kill the engine using the transmitter in 2 ways, a switch and low throttle.
Do you use a slide or toggle? Double Pole or Single?
Maybe a Normally Closed micro switch with a cam to open it to disconnect power?
How about a spring toggle switch? So many alternatives!
Which of these makes the most sense. I am a little concerned about vibration. With a switch to ground the ignition on a magneto system you can use a Normally Open micro switch and a cam with no problem but with a Normally Closed will vibration eventually cause failure?
Thanks, any input from the experienced will be appreciated.
