RE: Where is the receiver antenna?
Hi,
How does this sounds. My turtle deck is a foam and balsa sandwich there are a couple of horizontal supports in the fuse below the turtle deck, so i can run the extensions inside the turtle deck, and the antenna in a plastic tube on the bottom of the fuse. There should be about 6 inches of seperations between the two. Would this be sufficient?
Sebastian
