RE: 7C - Servo neutral points shift at different throw settings.
Hi Tom,
Before doing anything I would suggest going into a blank model and setting this up to see if the problem still occurs, this will eliminate any other programming affecting this.
But from what you are describing it sounds as though it may be that the pots need recalibrated. And in that case you would need to send this in to us.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
