RCU Forums - View Single Post - Split flap connection
Old 09-21-2005 | 02:59 PM
sledge_78
My Feedback: (24)
Default Split flap connection
I am currently building an older kit (F8F Bearcat) made by Long Island Hobbycraft & designed by Nick Ziroli. The kit provides direction for an optional inset aileron in place of the standard aileron which extends across the whole trailing edge. I plan to build the inset aileron this is a bit larger in width but only extends about 6 inches from the wing tip. I would also like to build and install flaps. The flap design would be a split flap at the fuselage and controlled by a single center mounted wing servo. Does anyone know of a manufacturer that makes a control horn assembly that would connect to the two flaps and provide a single interface fo connection to the servo. I know many yeas ago VECO manufactured a flap connector for their control line kits.
If anyone knows where I might make a flap connector I would like to know.
Sledge_78
