RE: OS 91fx Overheating
You need to make sure that your muffler is supplying enough pressure to the tank to give you good fuel flow. Some non-stock mufflers do not do a good job of supplying pressure to the tank, so the engine gets poor fuel flow and tends to run lean. Many modelers have to restrict the exhaust outlet of their after-market mufflers to insure good fuel flow to the engine.
