RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 09-21-2005 | 07:32 PM
  #3330
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Hey Gary... Just an update on the Skysharkrc.... I never could get in contact
with the guy at eagle, just his help that is running his hobby shop, he said he
heard about them but nothing more... But a few at the field said that S.S. has
been in Havasu for a while, selling their planes, but no real hobby shop for
parts etc...But that could have changed?.. But no reports on their planes and or
service... They did say a club member won a drawing of one of their planes at
a fun fly(not the 540) which looked good.... But he has never put it together....
Great 5hrs. this morning at the field... No UCD, But the 4*/Saito ran great...
Now using the 16X4W.... Guess I'll need bigger wheels... I only had about 1/4"
ground clearence with the tail in the up level position... Made a bunch of T.A.G.'s
and landings... And the prop is as it started... I was going to uninstall the
saito... But I readjusted the valves and had the new prop... So I had to try it..
Gary.. were you using this prop??? And the Profile is flying like it's old self?????
It was taking a bit more to hold it in a invert flat.... But the last two times out...
It pretty much went into it anytime I wanted it to... The last two mornings where
AZ. cool :-).... So I guess it was just the thin air??.....
cafusin....7500= Saito 100.... IMO.... I would go with the bigger mount also....
I think the stock tk position will work... Or just trim the F.W. hole and tank saddle
a bit... You can lower the tank 1/4 or a bit more before needed to trim the motor
mount, I used the stock marks for the engine mounts... That's what I did to mine..
If you do go with the Saito 100... At least make sure you have the 10oz tank...
which will fit in the location.. Seems like a few had the 8oz tks. and the later
models came with the 10oz???... My used UCD had the 8... and now a 10oz is in
there.... The saito will run a few seconds longer
On a little sad note... Members at the field were talking about how our "free" flying
site maybe close to being over in the unknown future and/or runway shorter....
Talks about shops and homes are getting louder[:@]..... You know what that means
