RCU Forums - View Single Post - First flight with BME 50
Old 11-06-2002 | 09:25 PM
CAPtain232
My Feedback: (40)
Default First flight with BME 50
You are in the ballpark with that needle setting. It is all dependant upon your climate. When an engine is new you are ALWAYS better off to run it a little rich, so continue to find the peak RPM as you have done and then richen it a LITTLE. NOW GO FLY, maintain enough altitude just incase. Since you have had this issue, I would fly like this until you feel it is safe to get down and dirty with it. Take it easy a log some time on that engine. As it breaks in you will need to adjust the needles some more.
Keep in mind I said a LITTLE rich. You do not want to maintain a rich setting for too long as carbon will start to build up in your engine.
Jeff
