RCU Forums - View Single Post - Run Time on a Walkera 3200 with 1800mah Li-Po
Old 09-22-2005 | 09:02 AM
jstanton's Avatar
jstanton
My Feedback: (14)
Default RE: Run Time on a Walkera 3200 with 1800mah Li-Po
Matt
The Li-Po bettery looks like the generic Li-Po. It has no name brand, but says it is a 1800mah 11.1 volt 3 cell pack.
Here are the Spec's on the battery from the person I bought it from.
Specifications:
>Flying Time: Over 20min (Continuos)
>Charger Time: About 60min
>Charger Function: Auto turn OFF
>Volt: 11.1v
>Weight: 110gram
>For use the helicopter or plane: Hummingbird, Feda, E-Sky, Dragonfly, Aerohawk or other mini helicopter
Her are the spec's on the motor:
Brushless Motor specifications:
Very powerful Brushless Motor 180 ~!!!
Working Voltage : 6-18V
Speed Constant : 3200RPM/V
Hollow holding current : ?1A
Impend-dance : 87m?
Dimension : ?20 X 40mm
Diameter of axes : ?2.3mm
Diameter:20.0mm
Length:47.5mm
Length of axes : 13.5mm
Installation bore depth : 3.5mm
Weight : 65g
(30A speed Controlle)for brushless motor
Thanks for your help.
ID:	327671   Click image for larger version
