RCU Forums - View Single Post - Split flap connection
Old 09-22-2005 | 09:49 AM
mcarleno's Avatar
mcarleno
Default RE: Split flap connection
Sledge_78,
Can't wait to see her at the field. There are a couple of ways.
1) You could use a long torque rod made from piano wire (I wouldn't recommend).
2) You could use a dual connector. Looks like a little fork that has one connector for the servo and two on the other side for two push rods (unless the flaps are close together this probably won't work.
3) You could use bellcranks.
4) You could use Sullivan Golden Rods (these will bend significantly).
Let me know if you need help landing her (LOL)!
Marc
ID:	327680   Click image for larger version
