Hi,
Should work fine on the Sanwa non-PCM gear..
see
http://www.mpx.speedkom.net/cms/vors...tip_ipd_gb.pdf
However, i have heard that on Futaba Tx, there have been issues with the use of The IPD..?
Again this could be that some of the advanced Tx units can transmit on either PCM or PPM
IPD works only in PPM transmission
hope this helps?
Anyone else using the benefits of the Multiplex IPD???
