is it possible?
so heres what i want 2 do.
i have a dragonfly 36, 30a esc 3200kv walkera motor 10t pinion
it has the original 2 rotor head. but i thought .. i could do with more..
so i want 1 or 2 more blades on the rotor.. total of 3 or 4... (maybe 5)
i thought if i put an extra blade and make the pinion 5t it might work..
but im not too sure.. will it draw too many amps with 3 blades even though the pinion is halfed.
and even if it doesn draw too much.. will the speed be enough for lift off?
i can do some minor modifications for the rotor head.
(i havent got one but im plannin on buying one.. thats if it will work?)
Thanks in advance
