RCU Forums - View Single Post - Latex help
Thread: Latex help
Old 09-22-2005 | 02:52 PM
BlackSheepThree
Default RE: Latex help
You can't wet sand latex. It does sand real well once dry. You can use 400. If your really want it completely off use acetone and a lot of shirt type/cotton rags and changes rags often cause they'll load up with paint. Then once all the paint is off you can srap autobody primer sanding with 220 between coats.
Hope this helps
