RE: Radio interference issues
Bax I don't thinki your explaination is correct. It would not make any difference how close the transmitters are if that is the case. The mixing occurs in the receiver.
I think the reason the AMA recommends a minimum space between transmitters is the possibility that one transmitter might pick up signals from the other tranmsmitter. Then the mixing would occur in the transmitter and be retransmitted.
