RCU Forums - View Single Post - idle high
Thread: idle high
Old 09-22-2005 | 05:17 PM
J_Bone's Avatar
J_Bone
Default RE: idle high
This is a chart for the Air and fuel mixture.
Code:
If the..	         Is..           Then the air density is..       adjust the fuel mixture to be..
 Humidity                 Lower	        Slightly more dense		Slightly richer
                          Higher		Slightly less dense		Slightly leaner
 (barometer) Pressure     Lower		Less dense			Leaner
                          Higher		More dense			Richer
 Temperature 	         Lower		More dense			Richer
                          Higher		Less dense			Leaner
 Altitude		 Lower		More dense			Richer
 Nitro %		         Lower						Leaner
                          Higher						Richer
